no heat in my 87 monte ss
chevyguy001
11-13-2008, 11:10 AM
i recently installed a new 350 cc motor in my 87 monte ss.all the wires on OG motor were not reused(most were).I turn the heater on ,no heat ,but fan runs all speeds.I dont know if vac hoses should be used or not. How to get that check engine light off?
Also i installed MSD 6al ,dont know how to install the tach to work with it ,any help is welcome, thanks guys.
j cAT
11-21-2008, 06:24 PM
the heater hoses should be hot,,both...if this is not the case then there should be a valve mounted on the intake where a heater hose attaches this valve should be vacuum controlled by the heater lever..
SCU
12-07-2008, 03:32 PM
x2. This is the same problem I had with my ls but I still havent gotten around to actually fixing it:rolleyes:
