Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Pick-Up
Old 11-12-2008, 08:49 PM   #1
rsmith8411
rsmith8411 Normal reputation
93 Pickup Won't Idle
93 Toyota 4x4 Pickup, 4 cylinder, straight shift
The truck suddenly got to where it won't idle when hot. When cold, it does fine, but when it warms up it quits when I let off the accelerator. Changed idle control valve and no improvement. Any ideas on where to go next?
rsmith8411 is offline   Reply With Quote
Old 11-13-2008, 03:11 AM   #2
discnik
discnik Normal reputation
Re: 93 Pickup Won't Idle
Checked your Mass Air Flow Sensor ?
discnik is offline   Reply With Quote
Old 04-12-2009, 07:03 PM   #3
Arizman
Arizman Normal reputation
I have same problem i need find out where i can fix
Arizman is offline   Reply With Quote
Old 04-16-2009, 09:06 PM   #4
rsmith8411
This post was for a friend's truck. It took me a little time to get with him on the details. He finally punted and took it in to a shop and they told him it was an intake air leak (he thinks it was an o-ring, but the shop wasn't specific). I would check all the vacuum lines and seals on the intake and look for a leak. Good luck.
Old 04-17-2009, 08:48 PM   #5
rhandwor
rhandwor Normal reputation
You can use carburetor cleaner and spray around injector bases,vacuum lines,and along the edges of the intake. If you hit a leak the engine will smooth out.
rhandwor is offline   Reply With Quote
Bookmarks
Google
Web AF
