Re: hard starting, dead spot, and bogs down
The engine is supposed to stall at around 4000 rpm in park, to prevent revving with no load, at least on my /94 3.4L.
(Many's the time I lay awake at night DREAMING I had a lean mixture I could top off with HHO generator for an extra 10 mpg, but thats another story).
If this happened right after changing the timing belt, I'd suspect you got one of the cams off by one tooth the wrong way...its a messy job taking all that off again, but this should be checked out...
The timing marks on my 3.4L weren't totally accurate and I had to make a half-tooth compromise, but got lucky, when changing my belt.
If you did it once, taking off the covers again and checking the marks won't be so bad.
Have you looked at the idle screw (yes there is one on mine near the throttle). I cranked mine up. I think the PCM adjusts for it anyway, but this helped mine start, having a slightly faster idle setting. Be careful because the screw is a hex key (on mine anyway) and is difficult to reach and incredibly stiff.
I found mine also would go into open loop especially on cold mornings, burning rich and running rough, until I tried this trick:
Turn the key on for about 30-40 seconds before cranking. If your oxygen sensor has a heater, this warms it up. The O2 sensor has to reach 600 degrees to work properly, and if it isn't putting out signal the PCM goes into open loop until it warms up.
When I did this, the car would start easier and run better.
I'm not sure if your /91 has a ECM/PCM or an OBD-I system for pollution control, but this may be part of the problem.
Also try replacing the PCV valve, that helped my car run better too (see my thread here on where it is).
Finally got my dream car:
- but I can only afford one this big.
