Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Pick-Up
Old 11-11-2008, 09:08 PM   #1
Patrick75
Patrick75 Normal reputation
92 22re pickup idle problems when brake applied
I just put a new Jasper engine in my 4wheel drive 92 Toyota pick-up. I now have an idling problem. When I apply the brake the idling goes up and down. I have adjusted timing and idling screw but it gets worse when I turn the idling up. I cannot find a vaccum leak either. Is there an idling sensor somewhere that could be causing the problem?
Patrick75 is offline   Reply With Quote
Old 11-11-2008, 10:35 PM   #2
Scrapper
Scrapper Normal reputation
Re: 92 22re pickup idle problems when brake applied
it could be your iac-idle air control cant tell you much more. you already tried timing and idle screw.
Scrapper is offline   Reply With Quote
Old 03-04-2009, 06:12 PM   #3
thebigyank
thebigyank Normal reputation
Patrick, if you get it figured out, please drop a line and say what it was because my 89 pickup with the same engine does the same thing. -Jonathan
thebigyank is offline   Reply With Quote
Old 03-04-2009, 09:34 PM   #4
fourwd1
AF -Advisor
fourwd1's Avatar
fourwd1 Normal reputation
Having the idle higher than spec will cause the problem you describe.
If you can get the idle down to spec it may solve the problem.
- - as seen in FOUR WHEELER magazine July 06 and OFF-ROAD magazine Feb 07 - -
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
fourwd1 is offline   Reply With Quote
Old 04-04-2009, 05:53 PM   #5
williedee
williedee Normal reputation
i have a 1991 toyota 4x4... it does the same thing how could you find the way to set it factory specs?
williedee is offline   Reply With Quote
Old 04-05-2009, 09:58 PM   #6
fourwd1
AF -Advisor
fourwd1's Avatar
You can find the Factory Service Manual online, GOOGLE the FSM for a 1993 Toyota truck.
89 4Runner - stock
Old 05-22-2009, 08:14 AM   #7
wickedlowss
wickedlowss Normal reputation
I had that problem when i bought my truck, i think i had to turn it down to about 750 http://www.ncttora.com/fsm/1993/engine.html
Last edited by wickedlowss; 05-22-2009 at 08:16 AM. Reason: http://www.ncttora.com/fsm/1993/engine.html
wickedlowss is offline   Reply With Quote
Bookmarks
Google
Web AF
