How to replace low-beam bulb on a '09 Altima?
My '06 Altima lease ended this past week, and I now have an '09 Altima 2.5S.
I replaced the stock H1 low beam bulbs on the '06 model three years ago by following the steps that were in a thread here.
On the left side I had to remove the washer fluid tank, and on the right side had to remove the air filter in order to get to the bulb housing.
Has anyone replaced the low beam bulbs on the '09 Altima and know if the procedure has changed?
The '09 model uses the H11 bulb type, so that means I can't install the H1 bulbs from my '06.
PIAA makes the same Xtreme Force 4700K bulb in a H11 configuration, so that's what I'll be using.
