2001 - Takes longer to start than it used to..sdsumike619 11-10-2008, 04:23 AM My 2001 Stratus is taking a lot longer to start than it used to.. Fortunately, it always starts at least. But I turn the key, and it tries to start, hold it there for a few seconds. Then stop, then sometimes I get lucky and it works the second time. But the bottom line is it is just taking longer to start than before.. Any ideas? ndcowboy 11-18-2008, 09:00 AM My 2000 was hit or miss when trying to start on cold mornings, (-10 F) when only used for town driving, and it only had 50k on odometer. I replaced the fuel filter, spark plugs and plug wires, and added heat fuel treatment. I also drove it on the highway 100 miles to get the engine good and warmed up afterwards. It now start great at even -25 F. I also recommend a block heater and try to plug it in when below 0. An outdoor timer set to cylcle on 2 to 3 hours before starting saves on electricity costs, just make sure it is rated to 20 amps. A household indoor timer is typically 15 amps and will burn out. Hope this helps, Russ vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
