Re: 2001 clio, electronic fault light comes on, car loses power
Hello james...
i have the same problem, mine started off like yours but over the past few weeks has got so much worse!!
im sorry to tell you that its not as easy as changing the battery.... ive had my car put on to a code reader, and nothing has come up, now ive been told its the icv (idle control valve) which is around £200 inc part & VAT.
so your best bet is to get it connected to a code reader and see what it
says...
this seems to be a very common problem with clio's, and as you might guess, renualt have not got a clio how to fix it!!
hope this helps..
if you find the solution can you post a reply...?
thanks
stuuuu
