96 motor and tranny swapjtom 11-08-2008, 10:29 AM I had a 96 sl1 that had a perfect motor trans and wanted to install it in a 96 sw2 also switched pcm car runs great but i have no 1st gear. need help:banghead: RC1488 11-08-2008, 12:42 PM I had a 96 sl1 that had a perfect motor trans and wanted to install it in a 96 sw2 also switched pcm car runs great but i have no 1st gear. need help:banghead: Hmmm.....switching over the SOHC PCM should have eliminated all your issues. You put the SOHC engine AND Tranny in the SW2 correct? If so id double check your grounds and wires. ive seen wires get pinched between the engine and tranny. also double check your grounds in the back of the engine. there are two attached below the 4th cyl intake runner. Replace your ECTS ? No? Do that also. RC1488 11-08-2008, 12:42 PM Any SES Codes? Automotive Network, Inc., Copyright ©2012
