Re: Hard to start when cold
...so.....I understand it will eventually start, as it seems implied that it will start better once warmed up....
..for some reason, mine will start immediately on second attemp when cold, but not on the first..I think the fuel line pressure empties when at rest (and indeed I have a small external leak at fuel pump unit) so the initial "primer" does not exist. On the second try, line has had time to pressure up during first attempt and then it starts right away...
and yes, I'd have thought of the temp sensor as a "false" high reading will keep the mixture too lean for an easy cold start.
..would it be possible that the EGR valve stays partly opened?....
I don't believe in miracles.
