Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Taurus/Taurus Wagon
Old 11-07-2008, 02:01 PM   #1
Wind3x
Wind3x Normal reputation
1996 Taurus GL Misfiring/Sputter 6 Cylinder 3.0L
About a week ago I was driving to my girlfriends house and along the way at red lights I could feel it idling rough. I got to her house and the service engine soon light was flashing indicating a misfire. So I drove it home the long way, and red lights it was idling like a semi truck. I got home and today I took it to Auto Zone. They did the reading and said it was a EGR valve, a mass air flow sensor and it was misfiring on cylinder 1. They said I should probably replace the EGR valve as it was clogged/stuck and that was causing problems to the mass air flow sensor and causing the misfire. I replaced the EGR valve today. It's still idling rough, light is flashing still, it doesn't quite feel as bad though. Now I heard also that if it was the EGR valve causing a misfire I should maybe replace cylinder 1's spark plug. Any other suggestions? Really stumped and aggrivated I just wasted 50 dollars for a new EGR valve.
Wind3x is offline   Reply With Quote
Old 11-07-2008, 04:40 PM   #2
LeSabre97mint
LeSabre97mint's Avatar
LeSabre97mint Normal reputation
Re: 1996 Taurus GL Misfiring/Sputter 6 Cylinder 3.0L
Wind3x
Did you get the code numbers from AZ?
Regards,
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
LeSabre97mint is offline   Reply With Quote
Old 11-07-2008, 05:59 PM   #3
Wind3x
Not quite sure which numbers you'd like I believe these are them.
One slip says, Troubleshooting P0402 (Is the slip indicating the faulty EGR valve.)
Other says, Troubleshooting P0301 (The one indicating a misfire on cylinder 1)
and the last says, Troubleshooting P0171 (The slip saying fuel injector issue/o2 sensor/mas air flow)
If you need anymore info let me know.
Old 11-07-2008, 07:27 PM   #4
LeSabre97mint
Yep...those are the ones.
P0402 EGR flow higher than expected (DPFE common cause)
P0301 Misfire on cylinder 1 (rear bank passenger side) (often caused by clogged EGR ports
This group of codes indicate a condition that the indicated oxygen sensor is reporting.
These codes are almost NEVER caused by a defective oxygen sensor or sensor circuit.
P0171 Oxygen sensor reporting too lean condition on bank 1 (rear bank)
I got the code meanings from here: http://www.automotiveforums.com/vbul...d.php?t=677408
SW MN
Old 11-07-2008, 09:18 PM   #5
Wind3x
So what would in your opinion be the next thing to replace? Also do you think it's drivable? I have a interview tomorrow.
Old 11-08-2008, 12:44 PM   #6
LeSabre97mint
Wind3x
Sorry I didn't get back to you.....it's tomorrow....did you drive it? How did the interview go?
To check if the EGR ports are pluged. Remove the vacuum hose from the EGR valve and plug the hose with something like a golf tee. This will set an error code. However, if the idle improves then we know that some of the cylinders are getting too much EGR because others aren't getting any.
Regards
Dan
SW MN
Old 11-09-2008, 12:46 PM   #7
Wind3x
Sorry about the long response I was at training for my job. Interview went well got a job as a PC spec at Best Buy. I drove the car it misfired about the half the time, other half was fine. This was after I replaced the EGR valve. I replaced the EGR valve and the mass air flow went away as did the EGR valve "Check Engine Soon" light problem. It's still misfiring so I took it back to Auto Zone and they say only problem was again, the misfire on Cylinder 1. Told me it's probably a plug/wire. The plugs looked fine and I brushed them off, I started the car, it ran perfect(It wasn't warmed up). It warmed up and it started misfiring. I replaced the plugwires, same thing it misfired. I don't see any vaccuum lines off if that could have anything to do with it. I'm stumped in what it could be, besides a....fuel injector. The weird thing about it is that I'll be going 60 down the road with the light flashing, then you can feel the car fire correctly and it'll speed up to 70+, like the it starts working correctly. Anymore info would be greatly appreciated.
Old 11-09-2008, 05:49 PM   #8
LeSabre97mint
Wind3X
Glad you got the job!
Have you considered the coil pack? I know that they go bad on Windstars. I believe heat can affect them too.
Dan
SW MN
Old 11-09-2008, 10:08 PM   #9
wafrederick
wafrederick Has more negative feedback than positive
The people at AutoZone are Idiots and don't know what they are talking about!You could have a bad coil which will cause a miss.It is not the egr that is bad for the egr code,it is the DPFE sensor that is bad.I have seen one miss on a taurus with a bad coil causing the miss.
wafrederick is offline   Reply With Quote
Old 11-09-2008, 11:59 PM   #10
shorod
Taurus Guy
shorod's Avatar
shorod Normal reputation
Careful making such a broad statement. My Dad went to work at AutoZone after retiring from running his own auto repair shop for 20 years. Prior to that he had spent most of his life working at other shops. He was a tremendous asset to AutoZone (and still is to me). Granted, AutoZone does not require anywhere near that amount of experience to be an employee and there are a few that don't know much about cars.
I'd agree that the misfire is likely due to a bad coil, especially since the problem seems to occur once the engine is warmed up. That's a fairly common way for a coil fault to show up.
-Rod
shorod is offline   Reply With Quote
Old 11-10-2008, 05:51 PM   #11
wafrederick
I take that back and do not ever trust them since being payed about $5.00 an hour and are not certified.AutoZone got in big trouble years ago,tried to charge people for checking codes which was a huge no no.This one I seen with a missfire,the shop they took it to said the engine was junk,were wrong and the coil was junk.Luckily had a good used one on hand and put it in with the missfire gone.
Old 11-11-2008, 04:02 PM   #12
robroy55
robroy55 Normal reputation
Hello, I was having a missfire on my 2002 42000 mi 24v at idle posted problem and Rod advised me to get NeW spark plug wires. I have always takne Rods advice and BINGO!! put the new wires on and NO More Miss!!
How many miles are on your Taurus.
Good Luck
Rob Roy
robroy55 is offline   Reply With Quote
Old 11-11-2008, 11:38 PM   #13
Wind3x
Sorry for the long response it's been hectic with work. I went to an Advance Auto near my job after work 2 days ago and the guy there seemed to know more than how to press buttons on a machine. After I had replaced the plugs/wires it was still doing it so he advised me it was the coil so he overnight shipped me one up for free. (My father was very displeased when he seen it had no distributor)
So I went and got it today, came home tonight put it in luckily wasn't bad to put in. Drove it around, the car seems a lot smoother and when I was driving the highway the light would actually stop flashing and would come back in a bit flashing. At red lights on take off where it's normally bad the car seemed smoother. It's still idling rough and I can still tell when the car is misfiring going down the road but nowhere near where it was.
Now my question is, I changed the cylinder 1's plug and it still was misfiring(before putting on the new coil) do you think it could have damaged the plug so that it's not running right now after the new coil? Also, the guy at Advanced Auto Parts mentioned something about it could have a bad valve as well. Would it be doing it all the time and not below 2k rpms if it were a bad valve?
The final thought of mine is, after replacing the egr valve and it still misfiring I tried putting a bottle of STP's water removal in my cars tank(was full tank), and the night before getting a coil I had went and got another bottle of Gumout's High Mileage fuel injector cleaner put in (Not thinking till after I put it in I had 3/4 of a tank of gas). Between the water removal and the fuel injector cleaner I had filled up of about a half tank of gas. I'm wondering could the fuel injector cleaner put in with a 3/4 of a tank of gas instead of full be causing some issues aswell?
I also should tell you that this car had sat for a while as I had bought it for $150 dollars(A steal beings though other than this the car looks/runs brand new) because the owner's daughter had hit a rock and busted the fuel filter and he thought it was the line(a hard 10 dollar fix). Could the car sitting there for maybe a year affect it? Should I change the oil immediatly beings though I've only driven the car for about a month now and put 1k miles on it. Just trying to think of everything/anything that could be giving me trouble, and I'm still trying to understand how the coil didn't fix the problem, only helped it run a bit smoother.
Sorry for the length of absense from my last post and my long posts. As usual any suggestions are welcome and thanks in advance for them, and the previous help. I hope to get through this without having to rip the block apart =/
Old 11-11-2008, 11:40 PM   #14
Wind3x
Also there's 160k miles on it. Edit button on the post seems to be messing with me.
Old 11-12-2008, 08:29 AM   #15
shorod
Taurus Guy
shorod's Avatar
If the check engine light (CEL) is actually flashing and the only code is a P0301, then the misfire must be occuring quite regularly. A flashing CEL means there is a detected fault that is causing increased emissions or potential damage to the emissions system.
What you could try doing is getting an inline spark detector/indicator and seeing if the spark on cylinder #1 seems to be going away when the misfires occur. These are usually available from most of the auto parts stores or Harbor Freight. If you have the DOHC V6, you'll probably want one like the Harbor Freight version since plug #1 will be recessed and not real easy to get to anyway.
If the spark tester indicates a lack of spark at the same times the engine sputters, then you need to keep looking at the ignition system. If the spark seems fine, even when the engine stumbles, then consider checking compression on the cylinders as well as verifying the fuel injector for cylinder #1 is working. There are noid lights for checking for injector pulse which often times can be borrowed from the chain auto parts stores as part of the Loan-a-Tool program.
Check the label on the fuel system cleaners. Usually they indicate the contents will treat from x to y gallons. If 3/4 of a tank falls within that range, you probably didn't harm the effectiveness. With the flashing CEL, it sounds like your car's problem is more significant than a fuel system cleaner will fix.
-Rod
-Rod
Bookmarks
Google
Web AF
