cleaning a Transmission Solinode pack?comet240 11-05-2008, 01:10 PM hi i like to know 1 how to remove the solinode pack from a 1991 pymouth voyager, from the transmission also how do you clean it if its clogged is there a way? littlebitofinsanit 11-05-2008, 08:04 PM it is like 3 bolt side and one and the back careful doing so if i were you i go to junk yard practice there these are sensitve and almost 200 buck to replace if computer dectects you remove wire harness trouble codes come up if goes to limp mode car will not go faster 40 mph 1 or second gear then have to flash computer then teach it which takes several hundred miles comet240 11-06-2008, 07:04 AM ok kinda confused, why is it so sensitive and whats sensitive on it that i have to practice at the wreckers? and why does the computer go into limp mode what is limp mode? but why does it need to be flashed? i read that all u do is unplug the battery for a bit then do the shifting for like 5 second things why does it take several hundred kms? right now i cant go faster really then 40km but i can when i let go of the gas and it drives at 80kms in like i guess 2nd gear or 1st gear as L 3 and OD run all in the same gear so would that be the solinode pack or something else?. but what is the flashing for and this limp mode? jpb53 11-06-2008, 09:59 AM From what you describe your trans is in (limp mode) right now. Limpmode is 2nd gear and reverse only. This is possible because of the manual valving in the valve body. The solenoid pack is not seviceable. It is a replacement part only. You need an older DRB2 or DRB3 with the right cables and cartridges or a scan tool like a Snap On MT 2500 with the proper cables. The scanner is connected inside at the same connector you access the BCM. The veering to the left on accel is called torque steer. More than likely you have a bad mount at the front of the eng; passenger side. comet240 11-06-2008, 05:00 PM so why does teh computer go to limp mode whats the purpose of that? what do you mean by "this is possible because of the manual valving in the valve body" ah i read about the solenoid pack could be serviced if u was the membraines but i dunno how, probably easier to replace the pack. now is it the pack thats wrong or a sensor? i see there is an input sensor what does that do? and how did the car go into limp mode? and it only pulls to the left on gas and right off the gas since the tranny was slipping and moving into this no gearing thing, before that it ran fine. what is a DRB2 or 3? what is the snap on 2500? is that the same as the OBD 1 code reader from canadian tire? www.canadiantire.com and look up OBD let me know so what is the BCM? i have no idea what all that means can the car no recorrect itself if i put a new pack in? caravan1997 11-06-2008, 06:25 PM comet240, I get an overwhelmoing sense that it might be wise for you NOT to take apart your transmission-I'm sure they can be very complicated.You might make a bad situation worse!Just my 2 cents. comet240 11-06-2008, 06:46 PM well i wasnt gonna take the tranny appart the solinode pack is on the outside of the tranny, i just wanna fix this so i can get moving again lol and i just trying to figure out what he ment by all thos abbrivations and what not Rawtorque 11-07-2008, 06:30 PM It would be best to have the DTC (codes) pulled from the trans controller first. It would be a waste of time to clean the solenoids of that was not the problem.:banghead: littlebitofinsanit 11-07-2008, 06:31 PM i was only implying if you mess with tranny use a wrecker part get expensive fast for tranny. limp mode is a nightmare for me dealer is 15 miles away not being dumb just becareful all that i mean comet240 11-07-2008, 11:02 PM ok why does the computer go into limp mode? what is that feature for a safetly thing or something? and why cant it fix itself and not get corrected normally how do i pull the DTC codes from the tranny? is that from a regular obd 1 code reader or something? jpb53 11-07-2008, 11:49 PM First Limp mode is when the(TCM) Transmission Control Module has detected a problem it will stop it's control of the Trans. That is why at this point yours is not shifting and you have second and reverse. DRB 2 and 3 are factory scan tools. With these tools you can access the computer; read codes, and check sensor inputs. Without this you are guessing when you replace parts. I can't access canadian tire as I don't have a postal code I have a zip code. I also suggest you take it somewhere and have it scanned or at least have the codes read. comet240 11-07-2008, 11:53 PM so when the computer detects that there is a problem why does it shut itself down to limp mode? is that a safety feature and why cant just unplugging the battery fix it? use my postal code k0l 1y0 like the engine service light hasnt come on yet, and will the scan tool guaretee that its working and this scan tool can it show live data and stuff for obd 1? as i only seen for GM u can do it Rawtorque 11-08-2008, 04:46 AM Limp mode is a safety feature to prevent further transmission damage if something fails. I strongly suggest you get a ATSG Service manual if you want to work on this trans. It will explain the DTC codes and how this trans operates. comet240 11-08-2008, 08:42 AM i supose there are no free ones online or someone have an online book? where can i get this book and did u check out the canadian tire website for those scan tools using my postal code to see if they will work? jpb53 11-09-2008, 09:30 AM Scan tool #25-1009-8 might possibly work; looking at the connectors available with it. They don't give enough info on-line. You might want to ck with the manufacturer. comet240 11-09-2008, 10:28 AM ok here is better break down of the tools from the can obd2 website that makes these http://www.canobd2.com/Products/Tools.aspx maybe u can tell me now? jpb53 11-09-2008, 12:26 PM No I can't; you are going to have to call them. comet240 11-09-2008, 02:33 PM ah ok so what would i exactly ask for then jpb53 11-09-2008, 08:58 PM Read the whole thread over again; the info on what to ask is right in this post. comet240 11-10-2008, 04:27 PM ok so ill ask for a tool taht will reset the tcm and DRB 2 and 3 so it will tell me the problem with the transmission i still dont even know what drb stands for comet240 11-10-2008, 08:17 PM ok i talked toa an obd guy from there site and he talked about the scan tool can remove the limp mode but he talked about when the engine light it showing i dont have any error codes so then really car isnt in limp mode? or whats going on jpb53 11-12-2008, 01:05 PM DRB = Diagnostic Readout Box. It is a factory scan tool. From your description your trans is in limp mode. You can have a trans problem and the light may not be on. Take it to a reputable trans shop and have the trans checked. comet240 11-13-2008, 01:38 PM ah ok would u think its the solniode pack? so i could just replace the pack first and get them to reset it? damn these special tools lol 96tsport 12-08-2008, 05:04 PM Good info here (http://www.allpar.com/fix/trans.html). Automotive Network, Inc., Copyright ©2012
