Transmission fluid for Corolla 1995juno 11-04-2008, 04:55 PM I have a Toyota Corolla DX 1995, I would like to replace the transmission fluid. Can you please tell me what type of transmission fluid I should use. Someone told me I can use the power steering fluid as a transmission fluid, is that true. I have purchased my car about two years ago, without any documentation. Any help would be greatly appreciated, Thank you in advance, -Jay Brian R. 11-04-2008, 07:53 PM If you have a manual transmission, use GL-4 gear oil If you have an automatic transmission, use Dextron ATF (which is the same fluid to add to your power steering fluid reservoir). If you have a 3-speed AT, you will also need to change the differential (final drive) fluid with Dextron ATF. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
