1988 3.9L Not Starting
I've done the basics; plugs, cap and rotor, battery, added some new fuel to the tank.
The plug wires seem to be okay and relatively new, though I haven't tested to make sure they get spark since the battery recently died.
I know I'm getting fuel, but it appears I'm not getting any through the injectors, of course it's a fine mist and I might not be able to see any on my finger when I checked.
It cranks over, but that's about it. The truck hasn't run in about a year and a half due to a previous problem, the fuel inlet hose was leaking severely and I've just replaced that.
Not having the tools to take off the bed or a large jack, I had to leave the gas tank on the ground for the time being. Would this affect the fuel pump's ability to send enough pressure even though I'm getting fuel to the throttle body at the fuel inlet?
Completely confused about why it isn't starting.
'94 4G37
Maintenance Comes First
Mods: Spectre Cone, MAF Hack, Weapon-R intake, intake wrap, all A/C removed, TB Ported, Strut Tower Bars, Prothane Sway Bar Bushings, Header wrap, Lightened, Full Grounding Kit, Fidanza Short Shifter, Shifter Plate Bushings, Shifter Cable Bushings and 2G shifter knob.
