93 Caravan
tbrown8165
10-31-2008, 03:39 PM
I have just replaced the fuel pump on a 93 Dodge Caravan. Now I think the relay went out. I would like to know which relay is the fuel pump relay. I, know where they are but they all look the same. :banghead:
Robertmchenry
10-31-2008, 04:23 PM
The fuel pump relay on my Caravan is in the fuse block under the hood, NOT the one under the dash. If you flip the cover over you will se a diagram of all the fuses & relays, the location & what they are for.
You should easly spot the fuel pump relay. Pull it & swap it with another relay, e.g. the ATX relay (Automatic Transmission relay). If the car starts your relay is bad, take it to the autoparts store with you and get a replacement. Should not cost over $10.00. Make sure you put the ATX relay back. Your transmission will not shift out of 2nd gear if the ATX relay is bad or missing.
If it's not the relay you might have other issues.
Keep us posted on your progress.
Robert
