im having some difficulties wiring a keyless entry system with remote start..
i dont realyl care about the remote start but since it has it.. i dont think it will allow me to just use the keyless entry... so i need some help with finishing the wiring:
in a 97 legacy L sedan
the keyless system = ultra start G11t
The wiring diagram from factory:
http://img136.imageshack.us/img136/2...img0904zj8.jpg
with a Change:
http://img373.imageshack.us/img373/2...img0907gp9.jpg
my wiring diagram resources:
http://www.angelfire.com/fang/doofus...less/99leg.pdf
http://www.angelfire.com/fang/doofus...6-97legacy.pdf
http://www.angelfire.com/fang/doofus...7-99legacy.pdf
http://www.angelfire.com/fang/doofus...s/97legacy.pdf
The Problem
I cant find the wires for:
horn (-) different resources say different things. two say it is red/green and from a 3 pin black plug and two sources say red/blue wire @ horn relay or keyless module (obviously this doesnt exist)
Parking light (-) it says to look for in headlight switch.... and should be black/green
idk where to look.... othere than taking the steering wheel covers off... is that really what i need to do...?
What is a ground while running output? (pin 12) and where would i find that...
please help confirm..
Parking light (+) im not entirely sure. but i do believe i have found it.
is this it? does it come out of the plug immediately above the fuse box towards the rear of the car. (that fits the description of red with silver dots in gray connector above fuse box) one source says to look next to ignition harness for that color wire..
so is the wire thats pulled out from the rest of the wires coming out of that molex possibly the one i need..? (i know its not clear.. sorry)
http://img373.imageshack.us/img373/9...img0897bk4.jpg
Brake switch input (+) the white one on the right right?
http://img373.imageshack.us/img373/7052/img0901aq3.jpg
please advise: im guessing i can just leave the following wires unwired..
pin 1: diesel wait to start input
pin 7: tach detection input (optional anyway and recommended to wire without unless car takes more than 2 seconds of cranking to start)
pin 8 & 10: re arm and dis arm outputs: i dont have an alarm... so can i leave that blank?
pin 9: no trunk release...
thank you thankyou thank you for responses!
