rb26dett Build Up?? Engine Managment?s13-rb26dett 03-17-2003, 05:13 PM I started the threat about the twin vs single turbo idea. I am going to do twin turbo set-up. I need help deciding on which ones and any other recomendations on turbo companies other than HKS. My goal would be to still have stock gear box so I want to do the best power up to that point for now and stock internals if possible your opinions. I would say about 500-550 Hp. What Engine Managment would you use? Apexi, Haltec, Electromiv....... I have a twin plate Exedy Clutch and full tein suspension. Will make custom Manifolds.... Have 72 pound injectors, and fuel pump....... I know Im aksing lots of questions and I appreciate everyones INput. Kyle tyndago 03-29-2003, 07:19 PM You can use stock exhaust manifolds - and a small set of turbos to make 500 - 550 whp. I would use a Apex'i Power FC as its plug and play... I like the HKS 2530's they work well.. You can use Apex AX53B60's.... but they are a little on the small side... vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
