Re: Interior lights stuck on.
I don't seem to have access to a wiring diagram for your 2004, but I did find a Technical Service Bulletin No. 04-6-4 that may be related. This TSB affects the 2004 Taurus and 2004 Sable. The issue is listed as: "Some 2004 Taurus/Sable vehicles may exhibit the dome light remaining on, multiple door ajar warnings, warning chime continuously sounding, and/or the luggage compartment lid opening."
The TSB claims that the factory scan tool must be used to monitor the Driver Power Window current PID. The issue apparently is a problem with the Smart Junction Box (SJB) and if the issue is found to be related to this TSB, the action is to replace the SJB and to install a jumper harness.
Is your Tarurus still under warranty? If so, you may want to make an appointment will the dealer. The dealer would not be obligated to cover the cost of a TSB repair, unless the vehicle is still under warranty.
For the time being, it appears there should be an interior lamp relay in the Central Junction Box (which may be the SJB - I'm looking at a wiring diagram for the 2002 model year) which controls the "puddle lamps" in the side mirrors as well as the interior courtesy lamps.
-Rod
