Re: my ka24det start up
well, what condition are your chain guides in? if they are broke then the chain was loose and can easily skip a tooth.. or if you had the distributor off at all or cams out, that could mess up the timing. put everything to TDC and see if its all lined up, if not, then you gotta pull it apart, line it up and put it back together carefully so you dont mess it up again..
