Re: Installing shelby glhs engine in normal omni
That depends on the year. I'm sure you're talking about a mid 80s model that has a 2.2L in it already and not an older model with a VW 1.7L.
If that is the case I would suggest just getting the engine and transmission from any 1989+ FWD Mopar. It's called the common block. It's stronger than any of the previous blocks. It's also cross drilled for cooling. It would have a 1 piece intake manifold. You can always find a two piece and put it on but they are a bit more expensive, more of a PITA, and they don't flow all that much more.
They aren't worth it IMO.
Now, again, I assume this already has a 2.2L in it. If so, then the common block, be it a 2.2L or a 2.5L will bolt right to the same mounts. For an Omni I would suggest a 2.2L engine.
Also, are you looking to go manual or auto?
