Re: 88 weird turn signals
I took a look at the Ford SM. I'd start checking for power with the engine on at the inside fuse box, fuse 5, 15A, which is for the brakes, signals, etc. That would be a start, either its the ignition switch side or the multi function switch side, which would include the flasher Rod was alluding to. I always think of a ground problem when there is a weird electrical problem. Oh, there is also the brake on/off switch that may be grounding your signal switch. But none of it makes sense with it working with the engine off, not with engine on.
