Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 10-27-2008, 10:07 AM   #1
morjackson
morjackson Normal reputation
91 Lumina sudden death problem
I was driving my 91 Euro 3.1 yesterday morning when it suddenly quit and would not restart. I tried some starting fluid and got nothing.
I checked it over, it's getting fuel and I can hear the pump working.
Fuel rail has pressure. Not sure how much but I replaced the pump earlier this year, so I don't think that's the culprit.
I let the car sit for a few hours and used some starting fluid and got nothing. No firing. The engine turns over and that's all.
I checked the computer, got codes 35 & 44. Code 35 is for the O2 sensor Which was replaced last year. 44 says it's running lean. (No kidding, no spark, no fire, no lean (no rich either).
Any ideas?
morjackson is offline   Reply With Quote
Old 10-27-2008, 11:21 AM   #2
cbec1999
cbec1999 0
Re: 91 Lumina sudden death problem
Check fuel pressure for starters. See youtube fuel pressure test. You might be able to rent a fuel pressure gauge from Advance / Zone.
cbec1999 is offline   Reply With Quote
Old 10-27-2008, 12:50 PM   #3
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Since the car didn't start on the starting fluid, you have no spark. Checking fuel pressure is irrelevant at this point because even if the fuel pump was completely inop, the car would have started on the starting fluid.
There are three common things that would cause a sudden no-spark issue on this car.
1. Bad crank position sensor or the wiring between it and the ICM (Ignition Control Module).
2 Bad ICM (these can be tested at most auto parts stores)
3 Bad ECM (computer).
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Old 10-30-2008, 05:26 PM   #4
morjackson
I wondered about the timing chain going bad and checked compression after checking the suggestions. Fuel pressure was right at 38 so that was good. I did a check on the spark and it was there on all 6 cylinders.
So, I did a compression test. it was all over the place. It wound up being a broken timing chain.
So far I haven't seen any collateral damage from it but will hopefully be back on the road tomorrow.
Thanks for your help and suggestions.
Bookmarks
Google
Web AF
