Re: random multiple cylinder misfire
Pull Dist. Cap The Sender Unit In The Cap Is Miss Reading , The Dist. Has A Little Metal Cup In It ,THAT THE SENSOR READS , It Has Come Loose , I Have Glued Them , Soldered Them In Place, Best To Replace Distributor , Just Remove Cap And Sensor , Some SENSORS Have Screws In Side Of Dist. Some Come Off With Cap , Remove Rotor Button , And LoOk And Touch Cup In Dist. If It"s Loose Moves It"s Bad ,
