ok stupid question, sorrywolfy692005 10-26-2008, 12:04 PM sorry if this is a repost... I have a co-worker that has a 72 mgb.. i am buying it sight unseen.. i have a question... are the convertable tops on these cars, mechanical or electric? thanks in advance Wolfy KimMG 10-26-2008, 10:48 PM Mechanical. You cannot drop it at a stop light like VWs or Fiats. You need to learn how to fold the top properly to avoid damage. You should look at the car before purchasing. Rust is the biggest problem. MGBs rust from the inside out. If the sills and rockers are rusty, then its value maybe just a parts car. kennybrocks 11-15-2008, 04:48 PM just got a 1975 mgb conv hasent run in a few years while checking ir over found on the starter wireing harness a white with a green tracer wire cut off at the starter end al other wires to starter are connected what is it for and where does it go KimMG 11-23-2008, 04:08 AM just got a 1975 mgb conv hasent run in a few years while checking ir over found on the starter wireing harness a white with a green tracer wire cut off at the starter end al other wires to starter are connected what is it for and where does it go Wiring diagrams are available at http://www.advanceautowire.com click on stock schematics. The white/lightgreen wire connects the starter to the coil on stock ignition systems. Automotive Network, Inc., Copyright ©2012
