Re: 95 Taurus GL Sedan Suspension Help
Looking at my Ford SM, the bar with threaded ends that goes from the bottom of the rear wheel spindle (knuckle, your #2) towards the front to the body frame is called the rear suspension tension strut (your #1), PN - 5A952(it only says "bushing," not the four needed). At each end, there are two rubber bushings sandwiched between two dished washers with the body in the middle, PN - 5A959, and the spindle in the middle, PN - 5K897. Unfortunately, you can't count on the aftermarkets to use the same nomenclature as the manufacturer, so that makes getting what you want the first time harder. Even the dealer parts have different names. The listings call the bushings a rear suspension tie rod bushing and a rear strut body end bushing for the two ends of the same rod!?!
It doesn't sound like you are referring to the rear stabilizer links (your #9, which connects to #5), but the bushings/insulators may be worn. They too could cause a knocking, rattling noise when hitting bumps and holes when worn out. Just thought you may want to rule that out. Of course the dogbone rear suspension arm bushings should be checked too.
