Re: Help! Keeps telling me door is open!
the sensor you're looking for is on the door frame of the car itself, located in the lower right hand corner if you're looking at the driver's door. it's a little rubber nub.
if you want to totally disable the voice module (bitching betty) it's located above the ecu in the passenger's side kick panel
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
