what did my service center do
navaho20001
10-24-2008, 11:41 AM
:screwy: i had a hard time starting my 02 chevy venture had to pump it in the am it would chuk a bit then start chk engine lite on shop said cylinder misfire so do a tune up, (tell me had to take top of engine off to do it) then fuel pump, then chk engine still on, low fuel light on, fuel gauge dont work chugs all the time ( yes there is gas) now telling me that need tp sensor(throttle control) and instrument control panel module i think the did something when changed fuel pump and tune up ??? what you think:banghead:
rockwood84
10-24-2008, 12:13 PM
the shop took the top of the motor off to put plugs and plug wires on. then put a fuel pump in ? now you got no fuel gauge pump not working correctly. if they did the work then make them fix it . but if the new fuelpump didnt fix it .then look at the pass-thru connector .its in the floorboard behind the drivers seat, if you sit in the second row seat drivers side it gonna be right below where your feet are. there are two under there the one that has the fuel pump ,fuel gauge wires in it is the bigger of the two. open the connector and see if it is green inside it. if so the go get a can of electrical cleaner and spray inside it and the plug to. if it cleans up good and the pins are not broken . get some dialectric cream and put a good bit in the connector. this will keep some of the moisture out that g.m. s seal on the plug did not. it is possible they didn't get the connector hooked up on the top of the fuelpump but let them worry about that.and do pay any more for them having to do it a second time.they done been paid.the pass-thru connector is just another one of g.m.s pi** poor design flaws.the lean burn cause by the fuel pump will cause a code for the tps. get the fuel straightend out and then see if it pops a code for the tps.
Airjer_
10-24-2008, 01:14 PM
Find a different shop! These guys are running you through the ringer! At least get a second opinion!!!
