Spark plug wire separatorsukdavid 10-22-2008, 01:38 PM I'm having trouble finding these things that will bolt to the side of the head without the continuous header flange getting in the way. Anybody know of a source? I've tried everywhere online I can think of. Thank you, David MT-2500 10-23-2008, 09:18 AM I'm having trouble finding these things that will bolt to the side of the head without the continuous header flange getting in the way. Anybody know of a source? I've tried everywhere online I can think of. Thank you, David Check your local parts places for add on stuff. Sometimes you have to make up some to fit the situation. Also local speed shops may have something that will work. Good Luck oldblu65 10-23-2008, 04:38 PM Try www.summitracing.com or www.jegs.com :2cents: (http://www.summitracing.com:2cents:) Jacfourteen 10-23-2008, 05:40 PM does it have to be mounted to the head? I know that there are plenty that mount to the outside edge of the valve cover, these wouldn't interfere with the headers/manifold. If you can't find what you are looking for on summit or jegs, I don't know that it can be found anywhere...they have everthing. oldblu65 10-24-2008, 02:30 AM You might also try checking at your local parts store ( I.E. -pep boys , autozone , etc. ) as they carry these spark plug wire separators in their " dress - up " stock section . I suggested Summit or Jegs earlier but they are by no means the only source for these items . They can be found in many locations . Pick up your choice of auto magazines such as Super Chevy , Hot Rod , Classic Trucks , or Truckin and look at the ads to see where to go to find what you need . You shoudn't have a problem locating them . Good Luck ! Automotive Network, Inc., Copyright ©2012
