Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 10-22-2008, 03:26 AM   #1
mudslinger88
mudslinger88's Avatar
mudslinger88 Normal reputation
Exclamation Heater core
Hey all, I am having some trouble. My heater core started leaking the beginning of last winter. I bypassed the heater core so it didn't leak and blow anit-freeze steam all over my windshield (took me a week to get it totally cleaned). I don't really want to go through another winter without heat. Has anybody ever changed a heater core. I would like to know what is involved with this job before I get eye deep in a pile of s**t. Thanks.
~2001 Oldsmobile Bravada 4.3L Vortech V-6~ (Running)
~2004 Ford Mustang 3.8L V-6~ (Running)
mudslinger88 is offline   Reply With Quote
Old 10-22-2008, 09:24 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: Heater core
Year make and model wo/w air?
Most heater cores take 8-12 hrs labor.
Have you looked up in the how to section?
MT
MT-2500 is online now   Reply With Quote
Old 10-22-2008, 06:41 PM   #3
ericn1300
AF Premium User
ericn1300's Avatar
ericn1300 Normal reputation
Re: Heater core
good link here with pics:
http://www.sytyarchives.com/howto/vi...imate_controls
Plan on a long day
ericn1300 is offline   Reply With Quote
Old 10-22-2008, 11:23 PM   #4
mudslinger88
Re: Heater core
Thank you ericn1300. I'm not sure what year that was on the post but I will definately use it as a reference. thanx. My SUV is a 2001 Oldsmobile Bravada. 4.3L Vortech V-6. I'm a real easy driver so I don't have to worry too much about 'jumping off the line' causing stress on the heater lines. I have the stuff to flush the radiator and system but I procrastinated and the heater core went out. Would that have something to do with the HC going? I'm not real great when it comes to climate control systems. I do have AC as well. I've heard, but not sure, that the heater system runs off the AC pump and certain parts of the AC system. That true? Thank you all for your time in posting and reading my crazy questions.
Old 10-23-2008, 06:22 PM   #5
ericn1300
AF Premium User
ericn1300's Avatar
Re: Heater core
Never heard of that, doubt that it's true. The climate control has a blend door to mix heated air with cool to your preference, but the sources remain different. The only thing I can think of that they may be talking about is that the AC does run when you turn your defroster on to dry the warm air to the inside of the windshield.
After replacing the heater core be sure to check for voltage in the coolant. Put the postive lead of a volt meter in the coolant and the negative to a body ground. Voltage should be no more than .03, anything more clean and tighten your engine grounds. Excessive voltage in the coolant will cause pin holes to form in the heater core.
Old 10-23-2008, 11:29 PM   #6
mudslinger88
Re: Heater core
Thank you so much for your help. I am going to tear into this POS this weekend. I will get back to you guys Monday. I don't have internet at home so I have to use it at work. I'm planning on a long weekend with this sucker though. Thanks again for the advice.
Old 10-24-2008, 09:54 AM   #7
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Heater core
You are welcome and good Luck.
Search the how to section for help and a good repair book that shows what to do on it would help you a lot.
If you get the right bolts/screws and wiring unpluged,
The dash swings down and out on it.
I always drop the steering column down and out before pulling dash.
Let us know how it goes.
MT
Old 10-24-2008, 10:19 AM   #8
cbec1999
cbec1999 0
Re: Heater core
Use the free dial-up. Might be faster than smoke signals (except for weekends )
cbec1999 is offline   Reply With Quote
Old 10-28-2008, 11:40 AM   #9
mudslinger88
Re: Heater core
hey ya'll. Didn't get a chance to pull the HC itself this weekend. When I'm pullin the HC, do I have to pull the entire dash, steering column, cluster, etc. etc. This is my only vehicle and I need it daily. Is there any way I can just pull the glove box and parts around it but leave the dash? I don't have to mess with the airbag or related system do I? Also, most pictures I can't access at work if they are online stored photos. Thank you all VERY much for your time.
cbec1999, the smoke signals have been kinda difficult to use anyhow. I keep burning the dang blanket. Maybe I shouldn't make the fire so hot. Anyhow, where I live (Dormitory) I can't even get the dail-up to work. This sucks! But s**t happens I guess. Thanks for the tip though.
Old 10-28-2008, 02:11 PM   #10
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Heater core
No.No.No. Way
Only on a ford and just some of them.
Do you have them wild dreams very often?
The dash has to come out on yours..
Look around the how to section and get some good repair info to help you along with it.
On the air bag just unhook battery a hr.or more before starting on it.
On the steering column put wheels straight ahead and lock column so steering wheel does not turn.
If you turn the wheel when steering column is undone it will put a world of hurt on the SIR clock spring.
MT
Old 10-29-2008, 06:56 AM   #11
mudslinger88
Re: Heater core
Yes I have them wild dreams all the time. That's why I ask about them before I put them into action. They get me into trouble. That really sucks. But thank you for the verification. I am going to get on this weekend. I have yet to get a new HC. Anything to look for in particular on the new HC to verify it's a good one? Should I do an fresh anti-freeze flush before or after I install the new HC? Agian, thanks for the info. It's much appreciated.
Old 10-29-2008, 10:10 AM   #12
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Heater core
You are welcome.
Just pulling your leg on the dreams.
But always pays to check it out before hand.
I always like to flush out first before replacing heater core if system is very dirty..
On flushing they make a flush stuff you can put in it and it helps to clean out engine block and rad heater core.
You flush out old coolant and add water and flush stuff and then run a while and flush out water and flush stuff.
Then add new coolant after heater core replace.
On replacing heater core get some good repair info on how to do it.
A factory repair manual or the All Data online sub is very helpful.
http://www.alldata.com/products/diy/index.html
Good luck
MT
Old 10-30-2008, 12:12 PM   #13
mudslinger88
Re: Heater core
Anybody know off hand what the dimensions would be for a 2001 Bravada HC? Anything in particular to inspect on the new HC? Thank you all for all your great input.
Old 10-30-2008, 12:29 PM   #14
cbec1999
cbec1999 0
Re: Heater core
When you put the hoses on the new one, put Armor-All (silicone) on the pipes. It will make them slide on easier, and prevent seizing.
The pipes will fracture easily on core bodies... USE CARE.
Old 10-30-2008, 12:37 PM   #15
mudslinger88
Re: Heater core
Thanx for the info. I'm going to pick up the new HC tonight. I will let ya'll know haw it all went down after the swap.
Bookmarks
Google
Web AF
