s-10 fuel gauge1buell 10-21-2008, 09:16 AM i have a 2000 s-10 and the fuel guage does not read anymore it jumps all over it will be empty one minute and full the next is there a home remidy or do i have to buy a new one cbec1999 10-21-2008, 10:26 AM Is this new behavior? Mine ('98 s-vehicle) has had strange 'characteristics' since I bought it. Reads correctly, but if I coast to a stop in neutral with 1/4 or less, it goes to zero as I stop, then back up slowly. Won't do it if I leave it in D, or if I coast down in N with more than 1/4. mike2004tct 10-21-2008, 02:40 PM i have a 2000 s-10 and the fuel guage does not read anymore it jumps all over it will be empty one minute and full the next is there a home remidy or do i have to buy a new one Sounds like the sending unit is bad. Could be a bad unit, or just a wiring problem/bad ground. Check all wires leading from the pump, and pay particular attention to any black wires that may ground along the chassis after leaving the pump. If it's the sending unit,you'll need to drop the tank, and remove the fuel pump to get at it. The sending units are only available through GM dealers. The other alternative is a whole new after-market pump assembly. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
