clutchjveik 10-19-2008, 04:21 PM how do i bleed the clutch on my 95 k1500? i dont see a bleeder valve anywhere on the slave cylinder kjr6306 10-21-2008, 06:47 PM Did you find an answer to how to bleed the hydraulic clutch on your truck? I have a 1993 and am trying to bleed my as well. I took the slave off to replace the starter and now the clutch is not working properly. Was hoping that bleeding it would help but cant find a fitting to bleed the system.... rhandwor 10-21-2008, 08:24 PM Do a google search for a new slave cylinder look at the picture closely. They have a bleed screw like a brake caliper. Some of them have a small boot over the bleeder. jveik 10-29-2008, 09:09 PM kjr6306 i have had that dilemma and it turned out that the rod that goes into the transmission wasnt lined up right with the hole and it would hit the case and not allow the pedal to be pushed in at all. i fixed it by carefully pulling off and re-installing the slave, making sure the rod made it where it was supposed to be. Automotive Network, Inc., Copyright ©2012
