Originally Posted by brandyboo
I have like 3 or 4 belts.
Should be 3. (1. Power Steering Pump (P/S) 2. Alternator (Alt) & Fan, 3.Aircond (A/C))
From memory - you'll need to remove the P/S belt first. The pump has a 14mm [edit - pivot] bolt under the pump (and above the alt) - it's accessed thru' the holes in the pump pulley. [edit - The lock bolt is clearly visible in the adjustment slot].
So where is the tensioner?
Do I need to go under the truck?
Yes (under) - removing the splash-guard (2 x 12mm bolts) will make access easier.
I need to find the tensioner
It's under the alternator. The tensioner has a 12mm lock bolt screwed into a block of metal thru' which the tensioner is threaded. The tensioner is 10mm. Loosen the lockbolt. Slacken-off the tensioner. Fit new belt - then re-tighten and lock.
Re-fit P/S belt - the tensioner is a 1/2inch square hole on the upper end of the bracket (lever it with an appropriate 1/2" drive). Tighten the lock bolt and then the 14mm [pivot]-bolt.
I think this belt goes around the fan pulley, harmonic balancer pulley, and the alternator pulley.
Correct.
