Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 10-18-2008, 12:53 PM   #1
kingjames1
kingjames1 Normal reputation
1995 jimmy front differential
I've been reading your posts and trying to figure out why my front differential won't engage. The driveline from the transfer case is working since I cannot turn it when the 4 wheel is engaged. But I disconnected the cable from the vacuum actuator and pulled it out about a 1/2" and tried to spin the right wheel with my foot, which I could. So I'm guessing something went in the differential.
Is that difficult to repair? The cheap repair manual doesn't even talk about it and I can't find anything online on "how to" repair this. It can't be that hard. I've replaced and rebuilt motors before but never a differential.
Does anyone know where I can find that info?
kingjames1 is offline   Reply With Quote
Old 10-18-2008, 09:14 PM   #2
2kTrailBlazer
2kTrailBlazer's Avatar
2kTrailBlazer Normal reputation
Send a message via AIM to 2kTrailBlazer
Re: 1995 jimmy front differential
my front dif went on me too. but it made a grinding noise( almost like a bad hub bearing). i think a new one was like two grand, i bought one from a junkyard for $300 and put it in myself. no intructions so i may have done some things i didnt have to do. but the whole front end had to come down. lower control arms and everything. took me 12 hours on my back in 11 degree weather. i think the book called for 10-11 hours.. im just a shadetree mechanic tho. no training. seems to be working fine now.(now i need a trnasfer case lol good luck. o by the way i was also working a 2000 i doubt much changed on the chassis in 5 years tho.
2kTrailBlazer is offline   Reply With Quote
Old 10-19-2008, 10:01 AM   #3
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
What was the other wheel doing?
The cabel should have a little more pull.
Does the pan cake diaphragm do anything when in 4W or 2W
Does the cable have any feel to it?
To get it to lock in you may have to turn drive shaft a little or spin the other wheel at same time.
The teeth on axel gears have to match up to spline in.
This link may help.
http://www.automotiveforums.com/vbul...d.php?t=572914
MT
MT-2500 is offline   Reply With Quote
Old 10-19-2008, 04:26 PM   #4
kingjames1
It doesn't have much vacuum at the actuator, maybe 2 in Hg. I was hoping that was all it was. I'll try messing with it some more like you suggest before I try a 12 hour repair. I want to get this done before the 15 degree weather sets in. Thanks.
Old 10-19-2008, 05:52 PM   #5
cbec1999
cbec1999 0
You weren't wrenching outside in 11 degrees were ya'? Cause if you were you're the manly type. I love the cold, but stayin' warm in that is hard just turnin' a wrench.
Takes a shovel to keep me warm at that temp!!!
cbec1999 is offline   Reply With Quote
Old 10-19-2008, 06:41 PM   #6
MT-2500
AF - Advisor
MT-2500's Avatar
In 4W it should switch to full engine vacuum.
If not look for the reason why.
Does it get engine vacuum to transfer case vacuum switch valve and the switch to the actuator in 4W?
Try jumping/running full engine vacuum to actuator for a test.
Good Luck
MT
Old 10-19-2008, 10:25 PM   #7
kingjames1
Ok. I'll try those things before tearing into that differential.
And, yes, I've done the snow and cold thing: crawling around on my back in the snow. Sometimes you have to do that out here in Ohio's snowbelt. It's that or walk up the drive in 2 foot drifts. Done that too.
Thanks.
Bookmarks
Google
Web AF
