1994 Explorer Missingkymagred 10-16-2008, 08:23 AM Started last week. It will start missing after it warms up and I take off from a stop, and going into over drive. I let off the gas then hit it hard it will run fine for awhile then it may start missing again in over drive. It does not miss while idling. I added "heat" thinking it may had some moisture in the gas, has not helped. What do you think may be wrong? Thanks Tony shorod 10-16-2008, 08:42 AM When's the last time a tune up was performed? Do you use fuel injector cleaner regularly? How old is the battery? -Rod kymagred 10-16-2008, 09:54 AM Not sure about the last tune up, Im the 3rd owner. I did put some injector cleaner last week, but I dont use it very much. shorod 10-16-2008, 01:14 PM I'd suggest you at least pull a plug or two. If it looks like they've been in there ahile, perform a tune up consisting of plugs, wires, fuel filter, and checking the air filter. -Rod way2old 10-16-2008, 02:46 PM I agree with Rod. From your description, I feel it is an ignition misfire. I would invest in a complete tune up, filters and all. kymagred 10-22-2008, 07:13 PM Just changed the plugs. It runs much better. I'm now thinking that I'm the 4th owner. It has 189xxx miles on it and the plugs look like they had 189xxx miles on them... Thanks, Tony shorod 10-22-2008, 10:09 PM Glad to hear it, and thank you for the follow-up post! -Rod Automotive Network, Inc., Copyright ©2012
