04 Tahoe Traction Control Problembarry1363 10-15-2008, 09:28 PM When I pull out on dry pavement my traction control takes over causing the vehicle to not accelerate. Even with the traction control turned off, the abs activates more frequently than normal. I read in one forum that the problem was possibly a bad wheel bearing. I jacked up the front end and both front wheel bearings seem to be okay, no movement. When I checked the rear I did detect some movement. Is this normal? Does anybody have any ideas what the problem could be? Barry deaaa 02-22-2010, 04:38 PM When I pull out on dry pavement my traction control takes over causing the vehicle to not accelerate. Even with the traction control turned off, the abs activates more frequently than normal. I read in one forum that the problem was possibly a bad wheel bearing. I jacked up the front end and both front wheel bearings seem to be okay, no movement. When I checked the rear I did detect some movement. Is this normal? Does anybody have any ideas what the problem could be? Barry Hi Barry. What was the bad part causing the the traction control to turn on? Automotive Network, Inc., Copyright ©2012
