bad viberations-96 sc2
emc73
10-15-2008, 05:55 PM
96 Sc2, 216k, 5 speed.
While driving, car vibrates under acceleration. I notice it occasionally at lower speeds, but mostly above 50. Worst between 55-65. And when you lift throttle, it goes almost completely away.
wheels are balanced
checked wheel bearings
Any help would be greatly appreciated.
Cat Fuzz
10-15-2008, 10:52 PM
I'd check the CV joints next. They could be worn and sloppy.
RC1488
10-15-2008, 11:27 PM
During the vibration does it change when the wheel is turned left or right?
+1 on the universals
cdc692003
10-17-2008, 02:51 PM
most saturns are bad about engine and trans mounts
check these also.
emc73
10-17-2008, 05:08 PM
Yeah its worse on left hand turns. Top motor mount changed last year.
SaturnRulz
10-17-2008, 06:37 PM
wheels are balanced
Is This The DOHC Twin Cam Motor???
SaturnRulz
10-17-2008, 06:43 PM
Is this the DOHC Motor- Twin Cam?
RC1488
10-19-2008, 10:45 PM
That points to a bad wheel bearing. Put the car up on stands and rock the wheel back and forth with your hands at the 12 and 6 pm positions. IIRC since its worse with left turns, the left left wheel bearing is bad.
And yes the SC2 comes with a stock DOHC motor
