Driving Lights off on GV 99'
Mareshalu
10-15-2008, 04:07 PM
My Plymouth Grand Voyager 99, seems to be playing tricks on me again. All of a sudden the driving lights went off, everything else works, except a weird light comes on in the dashboard - the hi beams indicator stays on no matter if it`s switched off or not since the driving lights problem. I checked the bulbs, fuses and changed the low beam relay and they all seem to be fine yet the lights don`t come on. I installed fog lights a while ago and they worked fine along the regular driving lights, I wonder if it`s a grounding problem, I still have to check that, but I doubt it. Thank you all.
RIP
10-15-2008, 07:31 PM
Could be a Body Control Module (BCM) problem. It controls the ground to the low beam relay coil. Try pulling the IOD fuse in the fuse box (PDC) next to the battery for a few minutes. This will reset the BCM and hopefully your problem.
Mareshalu
10-16-2008, 01:11 AM
Thanks a bunch I will do that first thing today.
Mareshalu
10-16-2008, 04:24 PM
Turns out the light bulbs were bad after checking them with a voltmeter :)
thanks for your input though.
