espace txenellybob 10-15-2008, 12:17 PM hi there wondering if someone can help i have a phase1 espace 2.0 txe was all working fine till about 2 weeks ago when the earth strap to the engine snapped replaced the engine strap but still wouldnt start found out that the little plug underneath the passenger side head light was not connected rejoined that and bang started up and ran fine for about a week then went out in it started it up and pop opened the bonnet and found out a relay had burnt out because of this i lost indicators starter motor windows main beam stereo the lot looked on ebay found the same relay replaced it but nothing the car now has me completely puzzled as too whats wrong if anyone has had this problem or knows of this problem please get in contact with me as i need the car to run again cheers nellybob 10-17-2008, 10:06 PM hi guys i have managed to get it to turn over but still not starting there is spark and the infectors are firing but still nothing kryten2x4p 12-31-2008, 09:50 AM I would say that you are nursing a major electrical problem. I doubt this will be easy to fix without a great deal of patience. Perform a full electrical diagnostic. With ignition on, try all electrics. Lights, indicators, reverse lights, front and rear fog lights, internal lighting, fan and heater controls, windows and central locking, radio and all instrument panel lights. If the above all works fine then the problem is most likely in the engine compartment and engine related components only. You could try pulling an ECU out of a similar model, but also check all plugs and sockets for corrosion of burnt terminals. I'm not familiar with espace petrol engines so you will have to use your head on that one. Hope this helps some. :smile: Automotive Network, Inc., Copyright ©2012
