Low coolant light
GTPSPEED
10-15-2008, 07:46 AM
ok, I am starting to think this will never go away.
I replaced the low collent sensor+ cleaned the hole
I did a complete coolent flush.
I bled all the air out of the system.
checked coolent level which seems fine.
Anyone have any other idea's to what I can do next besides stabbing a screwdriver through the light on my dash?
BNaylor
10-15-2008, 09:51 AM
What brand coolant did you have before the coolant flush and when the issue first started?
richtazz
10-15-2008, 04:09 PM
Also, did you inspect the wiring to the sensor?
doctorhrdware
10-15-2008, 04:23 PM
Also what you can do is measure the voltage on the connector, should have 5 volts or 12 volts dc.
HotZ28
10-15-2008, 07:59 PM
All sensors use a 5v reference voltage from the PCM, do you have that with the ignition ON?
hshift
10-16-2008, 09:40 AM
I had the same problem as you with my 99 GTP. The sensor itself was bad.
I think the new one was around $35. You have to take out the battery to get the new one in there.
BNaylor
10-16-2008, 09:50 AM
If you refer to the OPs first post he stated the low coolant sensor was replaced.
Also, you do not need to remove the battery to replace it. Just remove the passenger side headlamp assembly.
http://i5.photobucket.com/albums/y186/lizzywiz/DSC04039.jpg
hshift
10-16-2008, 09:53 AM
Double whoops, I guess it's too early in the morning for me. Sorry!
BNaylor
10-16-2008, 10:03 PM
No problem and thanks for contributing to the forum.
Just for reference gentlemen you will have 12 volts at ignition to on at the sensor electrical connector. There are two wires. Black/white which is chassis ground and a yellow/black which is the center pin of the electrical connector. The yellow/black wire is hot which comes from the IP cluster. The sensor is actually a P.O.S. and the circuit very basic even worthless. All the level sensor does is send a ground when coolant level is abnormal to the IP Cluster which in turn illuminates the low coolant warning light.
