Originally Posted by Goodyguy
Not sure how to do that. I ran an alligator clip with wire from pin 13 other end to ground. Tried with key on and key off. Is SES light supposed to blink? if so nothing happened.
also tried using code reader after grounding pin 13 no codes.
Code reader will not read transfer case codes.
After grounding pin 13 turn key on and Shift button lights wll blink code.
Post back code or no of button blinks and pauses.
Where did you ground it?
