Re: 99 Blazer starting issues and error code PO753
Ok, I don't have a fuel pressure gauge handy, but I guess I can track one down if need be. My manual says that I can activate the fuel pump by jumping a "red wire in the drivers side corner of the engine compartment, the the positive side of the battery". That sounds like a good test to see if there is a loss of power someplace to the pump, or if when jumped the pump doesn't run, then one can move closer to assuming the pump its self has failed. But, this "RED" wire??? is it the red wire in a 7 wire connector in that drivers corner, or is it a stand alone wire that so far I haven't been able to find????
