Good spark, fuel pessure is good if I run pump direct off battery, but not if connected through car wiring. Only momentary slight pressure when key is turned and then only a little during cranking sequence. Don't know how to check pulse on injectors and already checked fuses for hot, but will do so again. Had a Viper alarm and I had no info on it so I removed it and all related alarm wiring, thought it might have disabled fuel pump also.. I cannot find a fuse for the fuel pump nor do I have wiring diags for specifically my model.
Thanks,Ray
