10-12-2008, 10:13 AM
1988 s-10 blazer high idel problem
it is ideling around 3000 rpm and smoking it has new iac,map,tps,and inition moduel. new tune up and valve seals the comprecion is averaging 145 psi I an stumped how do I fix this problem?
10-12-2008, 10:20 AM
AF - Advisor
Re: 1988 s-10 blazer high idel problem
What engine?
For real high idle check gas linkage and vacuum leaks.
Also if a TBI pull it and replace base gasket.
MT
02-04-2009, 07:20 PM
My 2.8 was doing that, If thats what You have un-plugg the temp. sensor thats on the front of your intake, right in front of the TBI, if the idle drops its a bad temp sensor, replaced mine and it idles normal now
02-04-2009, 07:30 PM
AF - Advisor
Welcome to AF.
This post is old and dead.
Always check date on post and if it is old leave it rest in peace.
MT
AF - Advisor
Welcome to AF.
MT
AF - Advisor
Welcome to AF.
MT
