2007 Grand Caravan Washer Sprayer
pegger555
10-10-2008, 07:57 PM
My winshield washer fluid sprayer quit working (both front and back), Ive checked the fuses in the fuse box under the hood and they are good (is there another place to look for fuses?). I don't hear the pump trying to spray, and yes I have washer fluid in it.
RIP
10-10-2008, 10:58 PM
Find the pump connector at the reservoir and make sure the pins aren't corroded or the connector isn't loose. Beyond that let the warranty do it's job. Other players in the system are the Front Control Module (FCM), the Body Control Module (BCM) and the wiring between them.
It appears there is not a fuse just for the washer pump motor. The FCM controls it's power. If The FCM wasn't powered you would have many more problems.
vipergg
10-14-2008, 08:25 PM
Go under the hood in the fuse center and find the IOD fuse and pull for a couple of minutes and reinsert . You will lose your radio preset when you do this , this will reset the bcm which may fix your problem .
jgionet
01-21-2009, 11:53 AM
I have the same prob on my wife's 2005 caravan. checked the fuses and still no go. It just stopped out of the blue. Now to figure out if it's still on warranty :(
BroMontana
12-07-2009, 02:18 PM
I vote this the best answer. Thanks!
