Originally Posted by armallard
Sorry about that i guess i mis-read it. No replace stat yet. And the rad. was a little low.
If rad was low that could be the heat up problems.
Also check and fix all of the leak or leaks.
If rad is leaking it is best to replace it.
Check around on a new afternarket rad.
Putty on it is only a band aid fix.
Any time you have the stat out is a good time to replace it.
Also flush old coolant and replace the rad cap.
Let us know how it goes.
Good luck
