99 GMC Jimmy 4x4 Probs revisited
1999 GMC Jimmy ~ 115k miles
Had issue where 4x4 would not engage. Push switch, lights flash to 4 hi, here something try to actuate, an occasional clunk and it goes back into 2 wheel drive.
I looked at the vacuum under the battery cover, don't really know what I was looking at, but did not see any cuts or tears.
Friend tried to replace the TCM with rebuild and with new, same thing.
As of ~1 month ago, saw a decrease in fuel milage. Was getting ~ 22, now at 15-17 mpg. Realized then that I was stuck in 4x4 but button light still displays that I'm in 2wd. Press the switch, same effect as when I was trying to get into 4wd, lights up and goes back to 2wd.
Tried disconnecting battery overnight and reconnected, same thing.
Any suggestions what I should do next?
Other notable: Occasionally, if I try 4x4 on the road, I may get a slight grinding sound. Slow down and it stops.
Any help greatfully appreciated.
