95 Lumina Humming Noise
TheBigH
10-09-2008, 12:24 PM
I have a 1995 Chevy Lumina that has recently started to make a humming noise while going straight or to the left. When i start turning slightly right the noise goes away. There is no noise when idle and it seems to be louder at higher speeds. So what tests could i do to figure out what the problem is and how difficult would it be to repair myself? Any help would be appreciated.
maxwedge
10-09-2008, 03:15 PM
Welcome to AF, bad ft wheel bearing or a scalloped tire. Jack up the front and look for play in the wheel hub. Instructions for this job are at autozone.com, repair guides. Sounds like the rt wheel.
micmichael1983
10-10-2008, 11:40 PM
the way it sounds it is you front passenger side wheel bearing is going bad
TheBigH
10-12-2008, 01:12 PM
I jacked up the tires and spun both sides and couldnt hear any noise coming from either side. How else could i tell if the bearing is the issue or not and are there any other things i should check?
maxwedge
10-12-2008, 05:19 PM
With no weight or load on the wheel there will be no noise ,any play in the wheel/hub?
savannaz34
10-18-2008, 05:47 PM
you will not have any play in your wheel or hub,trust me on this one,it is your bearing
i just did my front pass.side wheel bearing
i doubted every one because i jacked it up,check for play and to me,it was not the bearing,but i said fudge it and took it apart(remove wheel,caliper,undo axle nut,remove four hub bolts)and sure as shit,it felt as if there was sand in there when you turn it:banghead:
maxwedge
10-18-2008, 07:55 PM
The play removes the guesswork if it is found in one hub, more times than not the hub/bearing will show some play, if not a road test doing figure eight manuevers will pinpoint the problem.
Schrade
10-19-2008, 01:25 AM
Get it in the air again, and grab and pull the wheel at 9 o'clock, and 3 o'clock position. Pull and push (not spin). Should be ZERO play.
maxwedge
10-19-2008, 09:46 AM
Correct!
