Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Escort
Old 10-08-2008, 05:44 PM   #1
chevyn0va1
chevyn0va1's Avatar
chevyn0va1 Normal reputation
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
po401 code egr valve
I have a check engine light and got the code that says poor egr flow. The guy at the store suggested I take it off and clean it up. Should help it because the code suggests the egr is ok.
My question is how the heck do you get it off there is like no room. Any special tool or tips?
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
located in beautiful New England.
How to remove the radio in ford esort
Air silencer removal
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
chevyn0va1 is offline   Reply With Quote
Old 10-08-2008, 06:25 PM   #2
mightymoose_22
mightymoose_22's Avatar
mightymoose_22 Normal reputation
Send a message via Yahoo to mightymoose_22
Re: po401 code egr valve
I dunno about the 99... but on my 94 I found it easiest to take the EGR off as an assembly with the tube connecting to the exhaust.
mightymoose_22 is offline   Reply With Quote
Old 10-08-2008, 06:29 PM   #3
chevyn0va1
chevyn0va1's Avatar
didnt think of that maybe if i can find where the other end goes i can try that. Good tip. Have you ever heard of this symtom?
Old 10-09-2008, 10:02 PM   #4
chevyn0va1
chevyn0va1's Avatar
I looked around this board and found a huge amounts of po401 posts and most say the egr is normally fine but a sensor infront of it called dpfe Differential Pressure Feedback Electronic Sensor or as autozone calls it egr valve pressure sensor su2108 (2 year warr) . I replaced mine for 55.00 and went over 50 miles with no light on time will tell though. wish me luck.
Old 10-10-2008, 12:54 AM   #5
mightymoose_22
Yes... I would bet that you will find your EGR all gummed up with gook... you might have some luck at cleaning it out, but a new one would only be $50 or so.
Old 10-11-2008, 07:12 AM   #6
chevyn0va1
chevyn0va1's Avatar
I did get a can of seafoam. They said to get some in the throttle body and in the pvc/brake vaccum line to get the product into the top end. So I did all that and poured the rest into the gas tank. While first looking at the throttle body, I did see more discoloration then my other car had. So I'll give the seafoam time to work and then look again.
Old 10-11-2008, 08:40 AM   #7
denisond3
denisond3 Normal reputation
If anyone wants to get the EGR valve off of a 94 Escort, I think the tool to use to unscrew the metal tube that comes from the exhaust manifold & fits into the bottom of the EGR valve, would be a 1-1/16" crowsfoot refrigeration wrench - with 6 points. (and use of plenty of penetrating oil). It would take a pretty good 'tool' store to have one though.
denisond3 is offline   Reply With Quote
Old 10-11-2008, 09:50 AM   #8
AzTumbleweed
AzTumbleweed's Avatar
AzTumbleweed Normal reputation
I'm not a big NAPA fan anymore but they can probably get you the tool overnight. Prepare to pay though!
Nevada Tumbleweed
AzTumbleweed is offline   Reply With Quote
Old 10-11-2008, 09:54 PM   #9
mightymoose_22
I have always just used two large crescent wrenches... turning iopposite of each other it has always popped right off!
Bookmarks
Google
Web AF
