10-08-2008, 03:34 PM
Won"t start
91 Jimmy with a 4.3L won't start. Done changed everything related to ignition issues. No spark at all. Any ideas?
10-08-2008, 03:51 PM
AF - Advisor
Re: Won"t start
Tell us what you changed and done?
Is dist rotor turning?
Coil and ign have 12 volts to them?
Has coil and ign module beeen tested?
MT
10-08-2008, 05:22 PM
Re: Won"t start
Changed the cap, rotor, ign. module, coil, plugs, wires.
12 volts yes
10-08-2008, 06:58 PM
AF - Advisor
Re: Won"t start
12 volts yes
Was they known good parts?
Is the dist rotor tunning when cranking?
Have you checked the dist pick up coil?
Are you checking for spark at coil or dist cap or on end of plug wire?
MT
10-08-2008, 09:51 PM
Re: Won"t start
They where bad or on the verge of going bad.
Will check in the morning.
Checked at coil and at the end of the plug.
10-09-2008, 09:54 AM
AF - Advisor
Re: Won"t start
Hard for them all to get bad at one time .
Throwing parts at it may wind up a bad new part.
Retest everything you replaced.
Can your parts place test the complete dist and coil for you?
MT
10-09-2008, 10:17 AM
Re: Won"t start
Vehicle set up for five months before I got it. Dist. cap and rotor was really bad, the ignition module tested bad, so did the coil. Will retest and thanks.
10-09-2008, 10:39 AM
AF - Advisor
Re: Won"t start
And do not forget to check/test the dist pickup coil.
MT
10-09-2008, 03:51 PM
Re: Won"t start
Appreciate the friendly advice, it was the pick-up coil. It was seized on the shaft, had to replace the whole set-up.
Again, many thanks.
10-09-2008, 03:57 PM
AF - Advisor
Re: Won"t start
You are welcome and thanks for posting back how it went and what it was.
Glad you got it fixed.
MT
