Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Sentra/200SX (USDM FWD)
Old 10-07-2008, 01:22 AM   #1
J_J_T
J_J_T Normal reputation
Unhappy Help failed smog check, 99 1.6 Sentra
I took the car for the smog check but failed, I changed the oil, oil filter, gas filter, air filter, spark plugs and gas cap. The car passed 2 of the emissions but the guy told me that the NO (PPM) was a little low and the obdII didn't pass the car because the catalyst Came Not Complete,
Oxygen sensor Not Complete, Evaporative Something Not Complete &
Egr Not Complete. What does this means It sound Like alot of money, The car had the Code P0505 Which I erased a week ago with my OBDII reader but no codes had come up since, Where should I start looking I can't think that the Cat, Oxygen Sensor, The evaporative and Egr valve went bad and no code would come up.
BTW Read on the internet after I posted the message that erasing codes before the test might affect the outcome of the test because of "drive cycles" and the night before I washed the engine and drove the car and everything was fine but before I went to the test I had a missfire in the number 3 I checked and there was little water inside the spark plug hole, I cleaned & Dried and erase the code to see if would happen again but it didn't. Do you think that was the cause? and if so How long should I drive the car before I go to the smog check again?
J_J_T is offline   Reply With Quote
Old 10-07-2008, 10:16 PM   #2
nismo_pilot
nismo_pilot Normal reputation
Send a message via AIM to nismo_pilot
Re: Help failed smog check, 99 1.6 Sentra
drive it for at least a week and cover all driving cnditions, hard accelerate, cruise at different speeds ect.
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
nismo_pilot is offline   Reply With Quote
Bookmarks
Google
Web AF
