95 caravan runs bad when warmcharlie40 10-06-2008, 08:11 PM I Have A95 Caravan That Runs Good When Cold. But When It Gets Warm It Misses And Dont Want To Take Off From A Stop. But Runs Fine At Highway Speeds. Any Help Would Be Great.thanks tempfixit 10-06-2008, 08:52 PM I Have A95 Caravan That Runs Good When Cold. But When It Gets Warm It Misses And Dont Want To Take Off From A Stop. But Runs Fine At Highway Speeds. Any Help Would Be Great.thanks Have you checked for any codes using the key dance? on/off, on/off, on within 5 seconds without starting engine. Check engine should flash showing codes. Example flash pause flash, flash means code 12. Post any codes. It could be a varaity of parts failing. I would check coils. Take a hair dryer and apply heat to the coils with the engine cold and see how it runs then, if engine misses cold then you may have pin pointed to the coils. Possibility of camshaft and crankshaft sensors also but start by checking coils. Hope this helps charlie40 10-07-2008, 05:31 PM Have you checked for any codes using the key dance? on/off, on/off, on within 5 seconds without starting engine. Check engine should flash showing codes. Example flash pause flash, flash means code 12. Post any codes. It could be a varaity of parts failing. I would check coils. Take a hair dryer and apply heat to the coils with the engine cold and see how it runs then, if engine misses cold then you may have pin pointed to the coils. Possibility of camshaft and crankshaft sensors also but start by checking coils. Hope this helpsI GET A CODE 55 THIS IS THE ONLY ONE. IM GOING TO CHECK COILS RIGHT NOW .THANKS FOR THE HELP RIP 10-10-2008, 02:29 AM If the coil is good consider a new upstream O2 sensor. It's a major component used by the computer (PCM) to calculate air/fuel mixture ratio and fuel injector pulse width. Both will effect acceleration and ignition. When it's cold the engine uses a set parameter to keep the engine running until the O2 sensors heat up. It's called "open loop". Once the sensor heats up the engine starts "closed loop" operation and uses O2 sensor data in it's calculations. You may see a mpg boost with a new sensor. They cost from $60 to $100. There is a consensus forming in the industry that O2 sensors should become a scheduled change item. They recommend for a van your age every 80k miles. I'm not sure if I would go that far but, if you've got over 100K miles it may not be a bad idea, especially the upstream sensor. charlie40 10-10-2008, 05:03 PM Thanks For The Info . The Coil Was Not It Still Looking. Im Going To Change 02 Sensor Now . Ill Post Up If It Works.thanks vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
